ak diesel driver
6.5 driver
Take the return line loose at the IP and run all 3 lines into a bucket and see if it changes.
Ok checked the fuel no bubbles as far as location of pmd I might put it back on the pump because this trouble started after I moved it in the first place pmd went the first time ten years ago when I looked on the net everybody said my location was good. As far as parts go 99%of all parts come from same supplier regardless of the parts dealer even from GM
That's way high.
I thought the top setting in the ECM for high idle was 1100 rpm.
Pmd has 100miles on it ECM 40milesSo optic sensor is out of the equation by the test.
Have you done the clear IP line to look for air? At this point I would disconnect fuel lines and run from a 5 gal pail. No water or gasoline smell in your fuel? Possible the fuel stop solonoid is sticking closed. Or loosing power and closing.
Time to wiggle the harness and see if you find a spot that changes.
This engine missing at idle? I can't tell from the video except it runs horrable. Then sounds like it hits all 8. ECM could be giving it more fuel to bring RPM up and it runs away when all 8 hit.
I really suggest a scanner to see what the ECM is seeing. Bat voltage, temp, air temp etc.
I am lost on what parts are "new". How many miles on them? Specificaly the PMD is it brand new or been run awhile? I would not throw parts at it.
Since no bubbles at all, get the fuel pressure gauge on there after the ffm and before the ip. That will end any guesses about pickup in tank, end lift pump guesses, etc. the cost will pay for itself when liftpump dies and it shortens ip life- you will know immediately and fix rather than wear out the pump.
I am leaning towards injectors at this point. Maybe pull the glow plugs, and crank it over. Watch the misting as it compares between cylinders.
Another option is crack injector nuts one to bleed any air that could be trapped in the injector lines but not showing up in return lines- can’t imagine this is the case, but is free and takes 10 minutes.[/QUOl
