Ahhh... this might be the culprit then. Definitely a rockauto clutch - listed as "GM GENUINE" although I have no idea if that means AC Delco or not. It does disengage but its on for far too long. Perhaps the issue is the lack of airflow through the H1 grille hitting that coil to cool it off sufficiently....
As for a light - no ... I don't have anything in the cab that tells me if the clutch is getting power or not. I was thinking about putting together something temporary, but given its a PWM arrangement - I was more interested in just using the built in hall sensor in the clutch - finding an off the shelf display for the hall sensor was challenging - finding a 12V driven display that takes 5V reference (iirc) was something that amazon didn't have readily available - and I don't know anything about arduino to do something like that myself.
EDIT: Tomorrow I'll take the tee out of the tstat housing and just put the 1/4" to 1/8" NPT adapter in. That will submerge the probe completely.
Also looking at the P400 crossover. Anyone have experience with these? They're practically giving them away (half the price of the original dual t-stat crossover)
