txgp17
Ok,
So after about 2 hours at the local Caterpillar dealer, I finally got a list of parts to retrofit a 364-5287 UHE fuel filter to my pickup. The 364-5287 is an “ultra high efficiency” upgrade to the “advanced efficiency” grade 1R-0751. The most recent filter testing standard, ISO 16889, doesn’t test below 4 microns, so there is no “standard” to test these “UHE” filters against. The popular 1R-0749 & 1R-0750 are both “advance efficiency”, so the UHE filters go beyond those in terms of micron ratings. If space is a limitation, you can also use the CAT 306-9199 filter, which has less capacity than the 364-5287. I would not recommend using these on the vacuum side of a lift pump. You'll likely need some pressure to get the proper flow them.
The smaller UHE filter (306-9199) is used on 3116, 3126, C7 and C9 industrial engines, up to 360 hp/ 925 lb-ft of torque, so I feel pretty good about it, and the filter head, feeding enough fuel to my 7.3L. I even found it being used on a C15 engine (926 cubic inches) on a generator set.
The filter head is part #141-5138, it was about $40; sorry I can’t find the receipt so I don’t have the exact price. The top of the filter head has a place for a manual priming pump, which I blocked off with a cover, part #6N-4414 ($11.42) and gasket #1P-0436 ($1.39). You’ll need two bolts to secure it, part #6V-2315 ($0.26) and #6V-5218 ($0.37). Yes, the two bolts are different sizes, but the CAT bolts have a nice oxide finish to them.
There’s also a place to plumb in a fuel pressure sensor if you like, but I plugged it with part #9S-4182 ($8.25). That plug seals on an o-ring, which is part #6V-5048 ($3.49), which is rated for fuel use, but I don’t know if it will resist bio-diesel. Sorry, I don't have the size for that plug.
Finally, the inlet and outlet are also o-ring seals, and those o-rings were part #3J-1907 ($0.89), and you’ll need two of those. These were the fuel rated o-rings recommended by CAT. The inlet and outlets are -6 Straight Thread O-Ring (STOR), using 9/16-18 UNF-2B threads.
The threaded stud on the filter head is 7/8-14, and the inside hole is 0.372” in diameter. The most restrictive part of the assembly that I can see is the cover plate for the fuel primer pump which is 0.312”, but I might run a drill through that to open it up a bit.
The head has two mounting holes, 0.36” in diameter, and 3.415 inches apart (outside edge to outside edge).
Below are some pics comparing the CAT unit to a NAPA 4770 with Donaldson P551313. The CAT 364-5287 is 3.4” in diameter, the P551313 is 3.675”. Please note, these two filters are not interchangeable, they’re just here for size comparison.
