Here is a list of filters and their part numbers that I have put together for the Duramax's!
DURAMAX Filter Guide
Oil
Baldwin - B1441
Donaldson - P550518
AC Delco - PF2232
Wix - 57202
Napa - 7202
Purolator - PL35399
Mobil 1 - M303
Amsoil - EA 052
Fuel
Baldwin - BF7827
Donaldson - P550743
AC Delco - TP1298B
Wix - 33910
Napa - 3910
Purolator - F55464
Parker/Racor - PFF5544
GM - 97385488
Luber Finer - LFF8736
Carquest - 86910
Fleetguard - FF5501
Hastings - FF1220
Isuzu - 8973854880
Champion - LFF8736B
Air *2006 and newer only*
Donaldson:
P610875 (White) - P612514 (Blue)
AC Delco:
A2947C (White) - A3087C (Blue)
Wix - 49184
Napa - 9184
Purolator - A35638
Allison Spin on Transmission
Allison - 29539579
2 Micron Spin on Fuel Filter
Baldwin - BF 7587
Donaldson - P551311
CAT - 1R0749
Wix - 33674
Napa - 3674
Fleetguard - FF5319
Luber Finer - LFF2749
Hastings - FF1056
Purolator - F75185
10 Micron Spin of Filters
Baldwin - BF614
Donaldson - P551712
CAT - 1R0712
Wix - 33374
For the 1"-14 filters, you can also add a Donaldson P553203 or a P553207. Both of these filters will fit the 1"-14 filter head, both are rated 99% efficient at 3μ, and are drainable water separators, but the P553207 is about 1" longer than the P553203.Updated some of the new 2009 fuel filters to the list. One for AC Delco, GM, and Donaldson.
You're welcome, and Thank you.Added. Thank you! And welcome to the forum. :welcome2:
Yeah, I've noticed that there ARE NO filters from Donaldson rated at 2μ absolute. Also, I looked up the P551743 you listed in the 2μ section. Donaldson is saying that one is 3μ nominal, not absolute. Which means it's likely 10μ or 7μ absolute.In checking on a few other filters, it appears that Donaldson is constantly updating and changing their filters. I just noticed that the P551311 used to be a 2 micron HE filter, and now it is listed as a 3 micron HE. :???: As always, just be sure to double check everything.
