Duramax Filter Guide
RI Chevy Silveradoman
At your service
Staff member
Lead Moderator
Rhode Island
Here is a list of filters and their part numbers that I have put together for the Duramax's!
DURAMAX Filter Guide
Oil
Baldwin - B1441
Donaldson - P550518
AC Delco - PF2232
WIX - 57202
NAPA - 7202
Purolator - PL35399
Mobil 1 - M303
Amsoil - EA 052
K&N - HP-3003
Fuel
Baldwin - BF7827
Donaldson - P550833 (2009)
Donaldson - P550743
AC Delco - TP 3012 (2009)
AC Delco - TP 1298B
WIX - 33960 (2009)
WIX - 33910
NAPA - 3960 (2009)
NAPA - 3910
Purolator - F55464
Parker/Racor - PFF5544
GM - 98081884 (2009)
GM - 97385488
Luber Finer - LFF8736
Carquest - 86910
Fleetguard - FF5501
Hastings - FF1220
Isuzu - 8973854880
Champion - LFF8736B
Air *2006 and newer only*
Donaldson:
P610875 (White) - P612514 (Blue)
AC Delco:
A2947C (White) - A3087C (Blue)
WIX - 49184
NAPA - 9184
Purolator - A35638
Allison Spin on Transmission
Allison - 29539579
Donaldson - P550606
WIX - 57701
Allison Internal Transmission Filter
WIX - 58970
3 Micron Spin on Fuel Filter (1-14 Thread UNS-2B)
Long Can Version
Baldwin - BF 7587
Donaldson - P551311
CAT - 1R0749
WIX - 33674
NAPA - 3674
Fleetguard - FF5319
Luber Finer - LFF2749
Hastings - FF1056
Purolator - F75185
Short Can Version
Baldwin - BF 7633
Donaldson - P551313
CAT - 1R0750
WIX - 33528
NAPA - 3528
Fleetguard - FF5320
Luber Finer - LLF3347
Hastings - FF1079
Purolator - F65213
10 Micron Spin of Filters (1-14 Thread UNS-2B)
Baldwin - BF614
Donaldson - P551712
CAT - 1R0712
Wix - 33374
Primary Filter/Water Separator (1-14 Thread UNS-2B) 2 Micron
CAT - 175-2949
Baldwin - BF1268,1214
Donaldson - P551743
Fleetguard - FS19683
WIX - 33005
Luber Finer - LFF8030
NAPA - 3005
Purolator - F60026
Hastings - FF864
Fuel Filter Water Separator (1-14 Thread UNB-2B) 3 Micron
Donaldson - P553207, P553203
TIP:
don't buy the allison spin on filters at the dealer. contact your local big truck dealer and see if they can get them. most likely it'll be much cheaper. my filters cost $39.99 at the dealer and $8.xx at the big truck dealer.
Damn... I was gonna go looking for that to make sure we didn't "lose" it, but I see you brought it along...
Thanks
Anybody getting a good handle on all the DIYs?
im being dum....can you explain the differance between the 2 and 10 micron filters?
2 micron filters filter out smaller particles than a 10 micron filter. I am not sure why they have so many filters with so many microns, but I suspect if you run them in a line of filters, they filter out different sizes along the way.
Here is a link that describes it better than I can. ;)
http://www.cat.com/cda/layout?m=37438&x=7
RI Chevy,
i don't think that's the right number for the LB7 & LLY air filters. i think you've only got the LBZ filter number on there. the wix/napa filter numbers for the LB7 & LLY air filter are 6678 (napa) & 46678 (wix).
Ryan:
You are correct! My bad. The air filters mentioned are for 2006 and newer! Thanks for bringing that to my attention. The other fluid filters should be good for any year.
TIP:
Thanks for the info. Wish I would have known that b/f:frown2:. Does the same apply to the fuel filters as well? I'm assuming so.
hit up fleet filter.com for fuel, oil and air filters. they sell napa gold (wix) filters for a lot better price than you will find anywhere else. i hope they're a vendor here because i'm sure they get a lot of our diesel business. i think its something like $6.xx for oil and $22.xx for a fuel filter if i remember correctly. rediculously cheap.
Going out on a limb here...how is the quality, same or better? (on the filters)
My son told me the filter on his LBZ is a larger filter than the LB7 filter on mine which is the newer version filter. He said it is not shaped the same. It makes me think it is something other than the standard filters. I think he installed a WIX on it the last time. He hasn't had the truck very long so there is no telling what it might be.
Are the filters different from the newer double pleat filters to the current LMM filters?
Thanks for the list. Good job. Did you make the filter part number corrections in the post?
George Morrison from AVLube.com ran some test on his truck a few months ago, comparing engine oil filters. He claims that as far as particulate filtration is concerned, the best engine oil filter he has found is the Amsoil EA052 -- He says that this filter is just about as good as running a bypass oil filter. But this filter costs $18.85 each.
I've been buying the WIX fuel and oil filters from FleetFilter. But I recently found out that my local Murray's part store sells the A/C Delco oil filter (PF2232) for $4.99 so I'm going to try them next.
