matuva
Tropical 6.5er
OK, we changed the accelerator pedal assy, key on key off 3 times.
We now get fuel at the injectors, but still no start, though it seems the engine may possibly start if the starter should be able to spin faster. Batteries are may be getting weaker (they are new) or the starter itself is dying.
So now, fuel at injectors, smoke at exhaust, even smoke inside cranckase (see pic ) but still no start.
We put the batteries in load for the night and we'll see what goes on tomorrow.
Here are the pics of the mod I found on the ECM harness. The green wire (#6) on the smallest brown plug has been cut and appears to be fed by a 12 volts source.
Any can tell what is this wire for ? Should I better cut that and restore harness as stock ?
