matuva
Tropical 6.5er
Guys, I feel a bit lost.
Recently, a 1998 K1500 just died while she was pulling a trailer with a boat.
She just die, and never restart till today.
I hooked my laptop with AE soft and found no codes.
Maintenance on that truck is poor, and I discover the lift pump was bad, and changed it.
Fuel filter was clogged, and fuel filter manager was full of crap. Even the small mesh plastic filter was missing.
I put on a new filter after I clean carefully the filter manager.
Plenty of fuel is now available at the T-valve, and up to the IP.
The fuel shut off solenoid clicks strong when keying on, no fuses are blown (ECM-B, ESO, etc...)
Disconnected the optic sensor;
tried another certified working PMD (the one from my own truck)
The result of all above is still no start and no smoke at exhaust. Crack injectors : no fuel or such a very few...
Put 2 new batteries after we killed the first ones. The engine cranck and spins strong, but not even a cough or smoke at exhaust. Obviously, it gets no fuel at the injectors.
Unfortunately, I have no spare PCM to try a swap, and one thing i haven't checked yet is the cranck position sensor.
I do believe the IP is shot, but I'm sure 95%...
What's your opinion ?
