handcannon
I'm finally getting to the point where I've got sort of a list made up. I didn't want to get too far ahead and end up with something I didn't really need, or find out I needed something I didn't have. Here's my list so far. I just need some other eyes and brains to make sure I'm not missing something.
1. standard rings for 6.2, gapless if I can swing the cost. I'm thinking it will be better to get file-to-fit since I'm dealing with re-ringing a used cylinder and not a fresh bore job.
2. Head bolts, I would like to go with studs because that's my personality, but in order to keep cost down I'm willing to go with TTY bolts (gapless rings take precedence).
3. timing chain (cloyes because of recommendations)
4. rear main seal? I'm leaning this way just because I'm already in this far
5. freeze plugs (same reason as #4, and they are not expensive to do now, but later?)
6. injector return lines w/spring clamps
7. copper injector gaskets. injectors are Bosch/India ones with only about 20K miles on them, may try to find someone local that can pop test them for me just to make sure.
8. Fel-Pro gskts, rebuild set
9. block heater? haven't tested the one currently in the 6.2, my digital multi-meter wasn't in my tool box of electrical wiring stuff and haven't taken the time to figure out where it may be.
10. transfer case to adapter gasket (the O-ring for the trans side is still in good shape) would just using RTV work for this since this are doesn't normally have any oil, unless some leaks past seals?
11. assembly lube, what's the best stuff to use? and exactly how is the best way to use it?
Is there anything I have missed?
The next items are dreaming, unless I can figure out a way to do them inexpensively.
12. remote oil filter, would be handy since my pickup is 4WD
13. remote trans cooler to move the stock cooler away from the radiator for more efficient cooling stack, also since the trans has just been rebuilt this would be a good time to make that change. (I do tow a travel trailer, about 7-8K loaded including what I put in the back of the pickup)
14. remote engine oil cooler, same reasons as #13
I know the above three items are not critical, but I can dream can't I.
Again, I'm looking for feedback on this list as I'm getting ready to pull the trigger on an order. Leroy, I'm looking at your web site and will probably need to call you since not everything on my list is listed on your site.
Don
Don
