n8in8or
Ok. I reviewed my pictures over and over. I looked online of examples of good patterns and then decided that I liked .023 the best. So I took everything apart and set it up for the last time. I knocked the old outer races out of the housing and installed new races. I pressed the new inner bearing on the pinion. I cleaned everything up really well and installed new crush sleeve, outer pinion bearing and pinion seal. I installed a new pinion nut with thread locker and put thread locker on the carrier bolts, too.
I ended up with 18 in-lbs of pinion preload which is right in the middle of the 15-22 spec for new bearings. Problem is that now I don’t like my pattern. It looks like too much pinion shim to me. So that’s frustrating. So I guess I take apart again and install different pinion shims and try again.
