1994ch
Ok here is the picture I get from what you are saying. Is there some better way to tie the 3" into the 4" frame? Thanks a lot for your advice.
bolt bed to frame using 3 to 4 pcs welded to bed per side
Looks pretty good, does Phil have you useing any torsenional gusset on the side to stop the bed from tweaking or rolling over on the frame, when a gooseneck is hooked to it?
Whats "pcs" ?
Looks like mine(B&W). My ball is not recessed, so the 'flip' sure comes in handy in making a flat, smooth bed.I concur, welding in the ball is feasible though it's not something I would leave up to someone who was not experienced. Most of the flatbeds I've seen or been around have something like this:
Note, the bracket welds in providing much more surface for your weld and it is not one of those folding hide-a-ball setups. It is a 2-5/16" ball rated for 30k lbs with a 7.5k lbs tongue weight.
