1994ch
Looks great. Thank you.
What do you suggest for the g/n ball. Something like 5" channel?
Exactly, if you're unsure of how to keep them square or get them square, let me know...........using a square or speed square don't work for this too good, should all be done with a tape measure from corner to corner........ check and re-check.......then check againI'm trying to remember how my dad built his flatbeds when I was younger...
I want to say he layed the large channel out (4" in your case), making sure they were square, and vice-gripped the ribs on (your 3" channel). With the frame layed out like this he could go through and make sure everything remained square, the vice-grips allowing him to tap or adjust the pieces as necessary. From there he went along and tack welded each rib in place, final verification of squareness, then completely welding the ribs in place. It helped that we had a nice flat concrete floor and nice heavy sawhorses that held the bed level as it took shape.
Nice job Phil that looks very good and durable,
