Ed HD
Formerly: Dad's 05 LLY
Wasn't there a member White Knight or something that had those PYO's?
don't know about superior...but my early 01's are stamped Hungary for sure...
My PYO's are stamped Hungary.
BTW Hungary on mine too and my '05 the same
As cool as teflon wheels are, I will tell you right now they are not very scratch resistant. Brandon (07HDclassic) destroyed a wheel in some mud on his truck. I personally like finished I can either re-polish or easily touch up/re-apply.Black powder coating or Black Teflon coating would be even better...
American Racing actually makes a Teflon coated set very similar to the PYO style
My dad uses that stuff all the time, it does work well if you want a durable finish. Now, seeing as he has only used it on gun parts, I don't know what something in a much harsher environment would do to it. I think it would hold up better than regular paint at least.http://www.brownells.com/1/1/5079-teflon-moly-oven-cure-gun-finish-black-brownells.html
$32.99
The Next Generation Of Durable, Spray-On, Professional Gun Finishes
Wheels look like they came back to their former beauty quite well. Good job Barry.At this point ,the wheels are looking much better than they did to start out with. All the polishing on them has turned them more gray and not as bright as they normally are. I had a spray bottle of some eagle ! mag wheel cleaner for unfinished aluminum wheels. I sprayed them down and then rinsed them off again[I had thoroughly washed and rinsed them after every application of stripper] It brightened them up but left them a little cloudy looking. A light polish with fine steel wool took that off.
Since i'm going through all this work with these I want to put some color highlighting on them before clear coating them again. The only paint I had that was any where close to the truck color was in a spray can of touch-up paint. I attempted to mask off all that I didn't want paint on and gave up on that idea about half way through the first wheel.So i sprayed some of the paint in the cap for the can and tried brushing it on. :nonod: Strike 2. The spray can paint is way too thin to even try to brush on.
Off to the parts store to try to get some color matching paint. Most parts stores don't mix paint any more. The parts store I went to was able to get me a pint from their supplier the next day:thumbsup: I ordered acrylic enamal because it.s too hard to mix the 2 part paints and use them up before they turn hard as a rock. A pint of the Hawaiian Orchid paint cost $35
I got 2 coats on the wheels where I wanted highlights and then went after the center caps and lug nut covers. I'm letting the paint cure on the wheels before I spray the clear on. I did a test on the back side of one of the wheels to see if the clear dulled the brightness of the aluminum. Not at all. :thumbsup::thumbsup:
Mike, those look amazing for being used in the winter. You must keep up on washing them. I know having the weights on the front kills a lot of wheels. When my dad bought his 09 first thing I told him to to was take it and have the weights removed from the front lip. Oh, and I hate powdercoat too, for the same reasons.I must be doing something right. Here are some pics I took today while I was rotating tires and lubing the truck. These have 155k miles, 5 salty N. Illinois winters and 3 sets of tires on them. I have never allowed wheel weights on the outside though...
And here's what I mean about not liking powder coat.
Dev, we just need to get you a new set of tires on order and peel the rims off and shine them up like mine.Mike, those look unbelievable. I need to clean mine up and post shots of them, no where near that nice. I run steel wheels in the winter so the only exposure mine have are from the cold snaps that hit early in fall or late in spring and they still spray de-icer.
EDIT: I do have outside weights and they are peeling a little there, but most of the peeling on mine is from the backside around the holes towards the outer face.
Good to know about the dynabeads actually working. Devin has looked into them, and I have also. The local tire shop here didn't think they would work...
Yeah, Putnam bragged about their powder coated products. But it's pretty crappy coating. It was starting to peel off the hitch rails in one year.Mike, are you sure that was powder-coating? Looks a lot like paint, most hitches I've ever seen look painted...
I'm not surprised as bad as mine was. But I did mean other powdercoated items lead me to not trust it as well as a good paint job. Maybe all I've dealt with is cheap powdercoating.I don't even live in the North and my putnam XDR was riddled with surface rust in less than a year...
This may be mainly a Putnam problem...
Been meaning to ask you in another thread how your Putnam held up. Think I'll start a hitch finish/refurbish thread then.I took my Putnam Hitch, sanded it down, and rolled on a Herculean type bedliner type finish to it. It has held up very well since then.
