staatsof
So I've finished my braking system refurbishment. It was a pretty big repair. I haven't added up all the parts but a good guesstimate is $500 in parts for:
New rotor, pads and SS hoses up front.
All new SS brakelines.
A SS drop hose in the rear.
New backing plates, drums, hardware kit, upgraded cylinders, bearings and seals and the tech bulletin specified brake shoes.
The tech bulletin prop vale was also installed.
Labor, additional supplies, the inner bearings in the rear and a new PS pump to hydroboost because it was leaking came to almost $2K.
The change was immediate but I'm going to make sure the rears are adjusted as they can be so I'm in for one more NC trip as well as their repairing an aluminum step the snapped with the lift. Argh
To me it's a whole lot better. I'm not done checking it out and I want the step on the driver's door fixed fixed first.
What surprised me were the rotors taken off. They're 3 years old, premium Raybestos with the wiggly slots and two sets of pads have been replaced in way too quickly a time frame or mileage IMHO. I don't know the caliber of that last set of pads because they were an emergency replacement but that's when the system really went down hill. The rotors look burnished a shinny black so I can imagine that the coefficient of friction was just awful. This explains the very poor performance. I'm not sure why they got this way.
I went with smooth Raybestos rotors of the same caliber (coated) this time because I needed them in a hurry. The wavy slots didn't seem to do much for my situation anyway. I wasn't expecting to have to replace the rotors which is more time consuming than standard slip over rotors and one of the ABS sensors had to be replaced as it was stuck in, so they said ... ? So this added a fair amount to the job.
Doing all of the brake lines was also a while you're command decision and that took time. The rear, cross axle, spring wrapped ones were the only horrible ones. But I had to order the entire set to get those. The reports are they went in just fine. A+ for Inline on that.
I'll post some before and after photos including the specs for the hoses I could find any other way. I went with rectangular banjos up front from Earl's but they sent me extended nipple round ones in the part number correct boxes. So I had to wait another week to fix that, very weird.
More later.
More later.
![0114190800[1].jpg 0114190800[1].jpg](https://www.thetruckstop.us/forum/data/attachments/43/43652-6a710327536870a867f881ed0151b26d.jpg)
![0114190801a[1].jpg 0114190801a[1].jpg](https://www.thetruckstop.us/forum/data/attachments/43/43653-b373f975182af124fe95ff3be61ba4f4.jpg)
![0114190802[1].jpg 0114190802[1].jpg](https://www.thetruckstop.us/forum/data/attachments/43/43654-cd6bc242e8b3df10a6d114453119f149.jpg)
