Big T
No bump stop trimming here.Did you have to trim the bump stop at all in addition to trimming the lower shock tabs? I saw the YT video where a guy did that when doing the LCA swap.
For anybody interested, I pulled up an old web captured version of the FSC thread using the Internet Archive. You should be able to see it here and the pics still work: https://web.archive.org/web/2015110...h/502106-obs-nbs-k2500-hub-swap-possible.html
It sounds like all pathways require a lot of effort, but the 99-00 LCA route does seem the easiest, trading additional required reaming for less invasive trimming, with the added benefit of no tie rod reaming (that year 800 brake lines may also directly fit without an adapter it sounds like?).
There's a few machine shops locally, I bet one of them is familiar with the process and could be more time efficient to pay to have it done if the cost isn't prohibitive.
I'm glad I asked because it looks like there are a few other less-documented tricks, including the driver's side LCA bolt behind the differential. I also mentally spaced that the torsion bars will need to be loosened. Good thing I'm not in the rust belt.
I have a set of ‘98-‘99 forged LCA’s, but the shipping cost is prohibitive. I’m keeping them as back-ups.
What is the trick for removing the Driver’s side LCA bolt? I’ve always had to undo and lower the front differential.
