DieselAmateur
Which holes are reamed 7 degrees and which are reamed 10*?
The GMT800 brake upgrade is NOT an easy swap on a 2 wheel drive, it's not even really possible to swap 800 spindles onto a 2 wheel drive 400 without extensive modifications to the suspension and frame(just updated the op to clarify). Gmt800's all use a knuckle with a hub bearing as GM was cutting costs by making 2 & 4 wheel drives use the same parts. On the gmt400, 2 & 4 wheel drives used completely different spindles, a arms, geometry, even the frame width was different.
The single biggest reason you cannot do the gmt800 swap to a 2 wheel drive gmt400 is due to how the lower ball joints connect to the spindle. On 4x4 400's and all 800's the lower ball joint points down at the ground and the spindle mounts below the lower a arm, on 2 wheel drive 400's the ball joint points up at the sky and the spindle mounts pulling up on the ball joint. Some have modified the lower control arms to point the lower ball joint down, but then you MUST put an equal drop in the upper a arm to maintain suspension geometry, and you lift the vehicle doing it this way.
This is the only way to do it with a 2 wheel drive With stock parts. Otherwuse you can go with the wilwood calipers, but they're big $$$$.
Big brake kit (my way)
Just have time to post this real quick, will be back latter to add more. Anyway Ive working on a Big Brake Kit for the 88-2000 trucks. This set up is for the 6lug 2wd and "might" work on the 5 lug and 8 lug trucks also, but I need to check it out first. The stock rotor is 11.5" dia. I wanted...www.thetruckstop.us
And a shim to make up the 1/4" difference for the brake pads to drw calipers on a 1.25" rotor would make for one heck of a noise maker.
Yes, it is not an easy swap, and requires custom machining to make work. I know I've said this elsewhere, but it wasn't in my original post on it(which I've remedied). The gmt800 brakes ARE far superior to the gmt400, but for 2 wheel drive guys, it is not an easy bolt on swap Like it is for 4x4 guys. I need to go through and clean this post up and add more to it that I have learned since I 1st made it.So the guff I got for being unwilling to convert my GMT400 C3500 2WD front brakes to a GMT800 setup was all for nothing?
Tom
He's talking about the updated valve for rear drums.@Oredigger97 are you converting to disc or upgrading existing.. ? Personally I'm trying to find correct proportioning valve also but because I'm deleting a.b.s. ..
I'm not quite ready to go there yet, I'm under the assumption I would have to eliminate the abs if I go that route. My burb only has 73,000 miles on it and is pretty clean, so that will be a last resort.@Oredigger97
I would be getting an adjustable unit like the ones used on track cars.
Just do some test driving on gravel roads and such to get the lockup adjustment right.
Thanks Husker, I'll check the wrecking yards for a abs unit from a 2000 escalade, that might be the easiest way to find one.@Oredigger97 That part (the upgraded proportioning valve) called for in the TSB for older Burbs was scarcer than hens teeth when the thread about it was written.
Iirc, a member on here had their local dealership parts guy do a nationwide search for the part and came up with like a couple at one dearlership, one at a couple of other dealerships and one at a couple of distribution warehouses and that was it. And that was a few years back before Covid. Not surprising that it's no longer able to be located now.
Since the TSB was for a retrofit, that means the change was made at the same time on the production line. I would assume that you would be able to find it on any post TSB-date Burbs in a parts yard, as well as a 2000 Escalade, which was just a 99 Burb with a different nose and plastic add-on body panels to make it a "Cadillac".
No, iirc, it is NOT the ABS unit that was replaced under the TSB, it was the combination or "proportioning" valve on the back of the ABS unit that gets changed out. Bleeding an ABS is a royal P.I.T.A. without the proper equipment, whereas bleeding the proportioning valve it relatively simple. Here is a PDF attachment to an article on this very subject for 1990's Suburbans with the P/N's of the parts needed.Thanks Husker, I'll check the wrecking yards for a abs unit from a 2000 escalade, that might be the easiest way to find one.
