simone0414
- Messages
- 112
- Reaction score
- 0
Well I took the turbo off & the exhaust manifold & from what I can tell it is coming from the gasket area right over where the starter heat shield is. From what little I can see the gasket looks fine & I see no evidence of anything that got caught in there when I put the head back on. There is nothing in that area but the gasket it could be leaking from IMO. I was able to get my torque wrench on the head bolts that aren't under the valve cover. I set it for 100ft pds & the bolts did turn a bit but not much. Hopefully my buddy will be able to come down tonight with the coolant pressure tester. I know this is a stupid question but can I try torquing those bolts down more to see if it will seal it up? I could take the valve cover off & check the bolts in that area & torque them down a bit more. I know your not supposed to have to do that but can I at least try without warping/cracking something. Only other thing to do is take the head.
