Will L.
No. Do it anytime.
I’m not sure what the book says. I believe that most times its preferred to do CT with engine at operating temp.So question on the compression test.... do I need to wait until morning to run the test?
I’m pulling everything down now. Removing the inner fender and getting everything ready at the moment
I think so. Guess only one way to find out, screwdge it into the hole and see if it fits good. After all, its just a check valve, rather it be for a tire or for a compression tester.I screwed around and got the schrader valve out. The spring was broken! Swapped out with one in another fitting and tried it. #1,#3, and #5 held at 400. With cranking up up 6 puffs. Went to #7 and it was bleeding down before I could read it. Pulled the valve and it popped the spring! I have a schreader from a tire stem. Can I use that ?
