Acesneights1
Sounds like maybe he needs a new Turbo that is less restrictive, HUMMMMM:biggrin5: that will also give him cooler intake temps.
It has a GM4. Not sure what you guys mean when you say less restrictive ???:confused5:
OK now I'm really lost. Bill H told me more boost was better for keeping it cool because I thought maybe I needed to cut the turbomaster back.Installing an I/C will help with temperatures some, but the excessive turbine restriction (backpressure) will still be there. The EGT's will also suffer under the rule of the GM-X turbo, driving that much more heat into the heads and consequently the cooling system.
He would likely have better results running just enough boost to keep his exhaust "clear" under load at WOT...
Regards,
Goldsburg
I wouldn't give up on your truck. I don't think you need a new turbo. We just need to find your problem. It is not a big problem or expensive, just hard to find. So don't give up.
hot air from cooling stack going into intake. thats what I think you should correct next and see where that gets you.
Cooling stack ???? you've lost me, there
. I don't quite undertstand what you said about Map pis vs Turbo ?
I think he's talking about the rad/AC Condenser/Tranny cooler/etc ...
Kenny cut up his stock airbox, so it's drawing in hot underhood air; the stuff is plenty hot after it passes through all those rads. Never noticed the significance of that initially, but Justin might have a good point.
Same thing happens to guys who use Walt's intake and try to pull hard.
Ahhh I didn't recall that mod, some will argue the point it don't matter to suck in underhood air, in normal driving difference would be negligible, but towing where you are really generating a lot of heat rate thru all the heat exchangers, it ain't helping any.
The airbox cut open mod is the one on Kennedys site. All I did was lose the snorkel(actually it wasn't there to begin with) and open the box a little more. it still draws air from the fender not the eng compartment. I'm leaning more towards needing an intercooler. The only thing i was going to try first since it will only cost me 30$ in R134a is yanking the a/c cooler out and taking it for a drive. If I dropped the truck down to 45-50 MPH on hills the temps dropped some.exactly, putting a load on the engine causes a lot of heat, and to circle it back through only produces more...
Kenny - have you done the TCC lock mod yet?
I know it was the final step of the puzzle for another guy I know that tows with his 2-dr Tahoe... that and finding the 'just right' sweet spot for towing (the speed at which everything stayed cool - in terms of gear, rpm, speed). Now he pulls a big load just fine, and his mods look just like yours. 95 tahoe, too, with a GM-4.
