Looking good. I've got that body style Suburban, but I have a straight axle swap. With all the room that I have I could put just about anything in there.
As for a down pipe, I wonder if the front most pipe on a Dmax exhaust would work? I have a couple I pulled from pick and pulls.
Measurements from what I think was an LB7 Banks delete pipe kit: From the V-band flange it is ~6" to the bottom of the 90* bend, a well rounded 90* that over curves to follow nearly 2" perpendicular from the V Band flange. It is 3.5" pipe.
Well the shape is close to what I had in mind, but it'll be cheaper for me to not have to cut the vband off and add something else if needed. I'll just start with a open generichttp://www.diamondeyeperformance.com/product_info.php?cPath=15_36&products_id=292
This is the diamond eye version of what I am thinking of. I kept the one I found at the salvage because it looked different.
Where do get the 90 degree with v band flange that comes off of driver side manifold? Why aren't you using mandrel bends?
This looks great so far. Would you consider making more to make available for purchase?
The v band fits a GM3 iirc, I was going to use it for my WH1C install.
Subscribing and scratching my head on this one.
