JayTheCPA
Those are the manifold to turbo pipes I have, there are some better flowing ones available. But of coarse a little more $.
How much more $ for the better flowing up-pipes?
Tune can be switched on the fly. Im actually going to switch my 96 back to DS4, but in OBDI.
I don't think a high flow version would have any real world affect on performance or MPGs were talking what 1/4"-1/2" bigger dia? but its pre turbo and such a short run. I don't think you would ever know the diff.
why obd 1 instead of 2?
Easier/cheaper tuning and the ability to run a multi tune switch on the fly chip
Sent from my Studio 5.0s using Tapatalk
Cheap (-er) reprogramming.
Can support multiple flash chips.
If you're really good, you can get "real time tuning" up and running on OBDI.
But IMHO, OBDI is a step backwards.
OBDII is more "tuneable", has more "depth" and as such has more potential/possibilities.
6.5 community sure could use a good reliable, afordable, timely tuner.
As for me the learning curve would be to big to get into it. I also don't have the time. (atleast I think those are my excuses, maybe its a simple thing?). Im 100% ignorant to the process.
Anyone have a picture of the front diff showing relationship to front of engine area?
I can get you one next week when I get home if nobody else can...
Sent from my SGH-M919 using Tapatalk
Meh, affordable is a relative term to me.
I would argue there are affordable options on the market already. While 500 bucks is a fair bit of coin to the average joe, it's reasonable considering what a "tuner" has to put in to it for the minimal returns it will bring.
It takes anywhere from 1,000-3,000 (-ish) just to get the equipment for OBDII. OBDI is a bit better, but you're looking at somewhere around 500-1000 for commercially viable stuff. Reputable tuners who do it as a business aren't going to mess with freeware stuff, they want support so they can overcome difficulties quickly. That's why more for the OBDI stuff than one would think.
Then there's learning what you need to do. That is literally hundreds of hours tuning and testing. That labor costs money. Then there's the cost of destructive errors. It happens when you are learning. Thousands there at least.
Now add into that the 6.X market share is infinitesimal. Literally infinitesimal compared to the Duramax, Powerstroke and Cummins crowd..
There's just no viable return on investment for it. Not if you're doing it as a business that is.
I do it as a hobbiest for my own enjoyment, nothing more. I don't charge guys for my work. I don't think I could even recoup my costs if I charged 500 bucks for a PCM. I'm only into OBDII tuning for around 1500 bucks (can do all years) but my labor time in learning it would be huge. About 3 years in my spare time and more Dyno time than I care to think about (although I don't pay for dyno time with the deal I have worked out). Guys like Westers and Kennedy may have dyno's in house which speeds the process up, but then there's the price of the dyno to recoup plus their labor. Guys like Bill learned it by (if I'm not mistaken) run and gun. That takes absolutely FOREVER to get it right. Trust me; forever.
If I was to make back any money at it, it would be from the modern diesels and even that would be "iffy". I wouldn't even consider trying to market a 6.5 solution, even if I did use tunercats dealer kit or by PCM exchange.
Personally, I don't know how someone stays in business only asking 500 bucks for a 6.5 PCM. It's just not viable. Too much cost to get it done, not enough market to make sales volume.
So I would call 500 bucks an affordable option, given the situation. Guys lament not having a $100-ish solution. That's just not realistic, although an understandable view seeing most don't have perspective on what it takes to get it done. 500 isn't bad at all, all things considered.
It just stings a guy in the wallet pretty hard when you can just barely afford one of these old hacks to begin with....
