Here is a cut & paste of Tanners link. Sounds like Turbonator is having fun. Its cool someone has done it. My plan is to skin this cat slightly different.
I actually made good progress on the QSV for mine today.
"well, heres an update after roughly 1000hrs. of service with the banks turbo manifold/custom front crossover in the rattlepuss (gmt400)
first i will list the drawbacks of the system, and the steps being taken to perfect it....
first thing (and the biggest)thats kind of a pain is the air inlet for the turbo, as most know the rad in the gmt400 uses a low coolant sensor located on the pass. side of the rad about half way up. this causes issues with the air inlet hose, it touches the sensor, and after a while it rubs through the rubber scrapping hoses, silicone couplers...
i made another inlet pipe with a tight 4" mandrel bent steel elbow which i cut a part of the side out indexing it, this worked for a bit, but sag of the silicone couplers caused it to rub against the sensor slightly tweaking the side of the rad and bending the sencor port down somewhat, it did not leak, but if left surely would, so yesterday i started another inlet pipe, this one i put in the vice and crushed the 4" down to make it more of an oval, after which i drilled a 4" hole in the furthest section where it is crushed and welded in a another 11/2" piece of 4" where it will attach to the compressor inlet with a short 2"section of silicone 4" coupler.... this set-up is going to save us 2" of space between the rad and turbo..... if anyone else is going to attempt this, i would suggest just investing in a rubber 4" cobra head adapter...
the second downfall of the set-up is the turbo oil-drain... the first one we built was the plate on the fuel-pump mounting spot, it works fine, but is a PIA to get it all attached.... since, we have drilled the front timing cover and put the return in there... this is by far the best spot for accessibility, but means that the cover should be removed and drilled/threaded to NPT 1/2" threads...
the third thing is the front cross-over, it all works great, saves 18" of pipe over the gm style, and does not leak, but if/when we build another one, instead of the 3 bolt flanges to bolt it together( to remove the crossover it takes someone with small hands, or the easiest we have found is engine removal...) we will invest in the 2 1/4" v-band flanges and clamps to save headaches,scrapes and cursing, and to facilitate ease of removal/installation....
now on to the bonuses of this system.......
first is the super quick spool time, it spools our current variation(WH1C,12cm2WG,56/83) by 1500rpm with minimal back pressure...
second, the ease of swapping injectors/glowplugs, the same job as a N/A engine, even with the intercooler tube on the driverside, swapping out 8 injectors/glowplugs is a 1.5hr job...
third, the ease of running a down pipe, super easy job, takes 2 45 degree mandrel bends, a turbo flange, and a section of pipe..... its 3" now, but could be 4" without hassle...
fourth, tranny inspection cover/starter/oil filter access, all made easier by moving the cross-over to the front....
fifth, ease of compound turbos, super easy with the banks mani, leaves all sorts of space for the downpipe, and primary turbo, we just weld a piece of tube to the valve cover for the oil return....
so off the top of my head thats all we can think of right now, will update the inlet tube progress with some pics of all the variations used so far, leading up to the current one..... thanks....J&J "
