FellowTraveler
Leroy a great build for sure.Should be ok on the overflow bottle, but I just remembered my A/C hose needs that space, so I'll have to find another location for it.
Good idea on heat shield for battery.
Im going to look at a gear ratio calculator and find what will be the best for me.Sounds like a good trip!
For using the aux OD I'd say 4.10's put you in the sweet spot for the att once you drop to 3rd.
It builds boost really fast, but with this gearing I ran most of the trip at 0 psi and on the hills kicked down to third and light throttle it went to 5 psi. I was afraid to push it hard so far from home so actually tried to keep the boost as low as possible.How well does the turbo spool with the new setup? Build boost any quicker ? and what was max psi?
MPG avg was 17'sGot any mpg numbers for the trip?
You were bout 3 hours from me at Amarillo.
US Gear is out of business. Only units are if you find one used.How about going with an Underdrive? That's what I've been pondering with my 3.42's. Wonder if US Gear would change out your unit?
Cheers
Nobby
