matuva
Tropical 6.5er
Do yourself a favor, remove the pass side wheel & inner fender, makes life so much simpler, while you are reworking your intake manifold let studs be soaking with PB blaster
X2 on that, I confirm and stongly suggest you do like Tim suggest.
I'm talking by experience. I did like that, and, even with inner fender still on, removing the turbo bolts was a piece of cake.
You get enough place to work on that.
In my case, the worst bolt was stuck, the one located on the inner side, close firewall. All we had to do was to use a socket with extensions, and a air gun. 30 seconds after it was out :thumbsup:
PB blaster will do fine, the old GM mechanics tip did wonder for me : after your engine has warmed, make a candle melt on studs and bolts... that really helps
