Big T
I need to some work, but looking for confirmation here.
I get the following codes:
Current Codes:
34 - Injection timing stepping motor fault
91 - Cylinder balance fault #7 cylinder
88 - TDC Offset error
Historic Codes:
95 - Cylinder balance fault #4 cylinder
Under TDC at idle:
Desired Timing: 8.6
Acutal Timing: 20 to 22
TDC offset: -2.02
If I read this correctly, then my timing is off by 10 degrees plus the TDC offset, which means that I'm off by a tooth on the bottom timing chain sprocket. I'm looking for confirmation before I start tearing it down.
Thanks in advance,
Big T :sad:
Current Codes:
Historic Codes:
Under TDC at idle:
Desired Timing: 8.6
TDC offset: -2.02
Thanks in advance,
Big T :sad:
