ak diesel driver
6.5 driver
don't have to but one less accessory to go bad
Well, added boost will add power when trying to climb hills and you defuel. So it doesnt add power, but it allows you to keep at sustained higher power levels in the stock program. So the boost fooler is a great thing if you dont have the aftermaket PCM program. So if its going to be several months, getting a $10 potentiometer from Radio Shack could make it run a lot better on hard acceleraiton to high RPMs, or under load.
The PMD relocation is a reliability modification that will save you time, money and tons of frustration, and trumps a performance mod :thumbsup:
so i cant have the boost fooler turned up at all with a pcm tune???
