Pretty good list, Dan... maybe a few tweaks, if ya don't mind:
First, here's the 6.5
Technical Reference Library - it's on a sticky at the top of the 6,5 forum.
Exhaust with downpipe: The factory exhaust is very restrictive, especially the downpipe. Putting in 3" mandrel-bent tubing will really free up your truck. This is really important when you add more fuel (with a chip) or boost (with a TM/fooler) because if the hot exhaust can't get out, your EGTs climb and you melt stuff.
I'm gonna add air here - diesels are big air pumps, and you need to be able to get air in and exhaust out to make them run right. Your truck is an 'S' model (the 8th digit of your VIN is S, means you have an EGR). Lots of those 96s still had extra webbing in the intake plenum that really restricted the airflow. John Kennedy has a good pictorial description of how to help your airflow
here. Putting on a TM to raise your boost will help push more in, but if the path is restricted, you just waste HP and heat up your incoming air (IAT) which is counter-productive.
Fuel - the 'Feed-the-beast mod is important - and I'm gonna add in "
as is having a decent lift pump".. if you can't get fuel TO the injection pump when your foot is in the floor, your truck just won't go. You really do need a fuel pressure gauge - they're cheap, easy to use, and help diagnose all kinds of issues.
Rest of the list looks good, Dan. I'm sure Buddy or some of the other guys will chime in and add to this!
Hey, 6.5 dragracer - that's a cute little truck you got! Can you post up some bigger pics? My olde eyes aren't what they used to be and that avatar is awfully small!
