n8in8or
That is absolutely true, the senses are definitely heightened when changes are made. That's why I don't trust myself right now.....is the shake/miss getting worse, or am I just paying attention to it more and more? I can definitely feel it at least through 2000 rpm, so it worries me. I will get the TDCO set and that can at least rule that out.Ones senses are more attuned when making major changes so a small miss on an old motor will often seem 'worse' with a new/different one...especially when one is expecting old issues to be solved by the change in power plants.
My truck ran a little 'odd' or rough during break in and for the first couple thousand after swapping engines. It smoothed up after getting the IP timing set. My injectors were balanced prior to installation.
If the old tune and new tune still have the miss, then you've got something else going on. Mine has always had an occasional 'skipped beat feel' regardless of motors, tunes, turbos, injectors, air cleaners, fuel, IPs, and FWIW I'm currently running Heath's HT-4 cam.
I have the old tune in still and it felt a little worse to me in my 5 minute drive to work, so they jury is still out on whether the problem is less with the old tune or not. Yeah, I don't think the tune is the problem, but it is interesting that it changes with the tune. If it continues to be less with the old tune, then I think that is a clue.
