n8in8or
I kept the stock mounts.I 2nd what Jay said.
Can't remember, did you install Poly engine mounts? That could be why.
No, not yet. It does seem to still have the shake when it is cold with the extra ignition advance, so I'm not hopeful that messing with the timing will take care of it. I do still plan to do that though, yes.Did you ever do a timeset TDCO or?
Well.....Joe Heath said it was known to have drivability issues but I think it was a ploy to buy their cam.With no CEL it likely isn't a code.
Is the new cam known for a rough idle?
Yeah I get that and had an expectation that this could happen, but as time goes on this just doesn't feel right. And that's another thing, it can be felt more than it can be heard. This isn't anything like a gas engine with a hotter cam. I wish one of you guys with more experience lived close by so you could experience it.I'm no expert but I would guess cam and rockers would make some changes in how it sounds.
Yeah that's my thought too.....If your brothers scan tool can shut down injectors, that would be a good place to start. The 2 or 3 you couldn't reach are the likely ones.
Yeah I did that once, but only on the 6 I could get to. I think tonight I'll do it again to all 8 and try to really listen to see if I can tell if one is less affected than the others.Crack the nuts one at a time on the injectors if you think it one or two that are bad. Listen for a difference between cylinders as you do them.
If you don't notice anything that way, wait until you do the learn before anything else.
Thank you for that info Jay. I'll see if my brother can look at that while he has it hooked up to do the TDCO. I keep looking at that Car Code software, I'm just not sure if my old laptop is healthy enough to run it. That would be ideal to get long term.Consider either tracking down a scanner or purchasing the software to get injector flow balance. FERM did a great write-up on what to look for: http://www.thetruckstop.us/forum/threads/proper-way-to-check-balance-rates.41579/
Do not recall the injector's history from this thread and, if they were not inspected, consider getting them rebuilt. I had a set of marine aftermarkets go bad in just 10K miles. I now have Bosch marines set to 2300 and they seem to work well with the ATT.
