FellowTraveler
See that upper indentation in your firewall it's for clearance when installing the 6.5td centermount turbo motor.
Nice job there!
Nice job there!
Nice job there!
The firewall matches the firewalls on Burbs in down under that came fitted with side-mount turbo because of steering box & column location on other side than ours.
I did the same insulation inside the front passenger compartment firewall, footwells and drivetrain hump made a big difference in heat rejection and sound reduction w/non-porous foam sleeping pads.
Helpful link: http://sectionhiker.com/sleeping-pad-r-values/
Correction to post # 203 say's "side mount" it should read "center mount", end.
Yeah I figured it was worth a try. I hear ya, our Class C with a 460 sure isn't quiet so I can't imagine what a van with a diesel right next to you sounds like!That sound paint looks interesting, wouldn't mind putting that on my tin so its quieter, damn van's,![]()
Where did you get it?
I'm pushing 66 and suffer from sometimers.Unless you're going with a different turbocharger, there's not a lot to gain in going center mount. The OEM BW unit isnt the best starting place.
Pretty sure the van/Hummer intake manifold also has different bolt angles than the truck heads. Would at least have to redrill or build a shim to get proper bolt clamping without side loading the bolt head. Don't quote me on that though, the gray matter is getting a little dodgey these days.
I got the Tunnel Shield finished on the firewall. I just need to tape all the seams with foil tape. It didn't go too badly overall. I think I have about 3 hours into installing the Tunnel Shield and of course I got faster as I went. One thing that made it faster was not worrying about making perfect butt joints and letting it overlap. I also ended up putting a second layer in the middle of the firewall to cover seams and also to hopefully get additional sound deadening there.
Are you going to put the thick mat over top of the Tunnel Shield in the center area?
I did the same procedure with a different product. I had to do it because the thin material that was there was brittle and crumbling off. I installed the thick mat back over in the center area. I figured the thick mat had different sound deadening properties than the foil urethane sticky back stuff.
Good looking project.
