n8in8or
This is hard to explain......I don't have less power as RPM increases, I have less power directly related to throttle position. So I can be at 2500 RPM and 3/4 throttle position and have more power than I do at 2500 RPM and FULL throttle. The throttle pedal is acting correctly because when I had Car Code hooked up before I saw that it was displaying 100% throttle input and it also does control the RPM that the transmission shifts. So what I'm expecting to see with the data logging is what fuel and timing is commanded at 3/4 throttle and at full throttle and hope to find a clue there. So my problem shows up dependent upon throttle position, not RPM dependent, so there must be a parameter that is changing based on throttle position that my engine isn't liking. It did this with both IPs also, so it isn't an IP problem.
In addition, I did try swapping in the old tune and the problem isn't there....however, the new tune at 3/4 throttle is stronger than the old tune at full throttle. So the new tune in general is putting out more fuel, something is just off in the tables based on throttle position. I'm hoping the datalogging will show me something in the fuel and timing that I can relay back to Heath to get this figured out.
The more I read, the more I think I want to go to a mechanical pump. I like the price of the Peninsular pumps, but I feel like Unique Diesel might have a stronger pump for the GMs, but I don't know that for sure....I'm still reading. I will stay with the electronic setup for a while as I'm sure that once I have hard data showing what's going on with my tune I will be able to get it sorted, but for maximum power that this engine should make I think I will need the fuel that a mechanical pump can put out.
Yeah good points on the dyno inaccuracies, I would still hope to see a change to the shape of the overall curve between 2 cams and that at least would be a little informational.
