n8in8or
Now as far as build details go, I was able to mock it up and verify pushrod lengths and valve-to-piston clearance.
My modded lifters that I tack welded to make solid didn't work. I had to keep the tacks small to make sure everything still cleared and using a MIG it just wasn't enough weld. If I had a TIG this would have worked, but I haven't reached that level of cool yet.
So Plan B: I had read of people disassembling lifters and installing small washers to take up most of the internal space and then filling the rest of the void with JB Weld before reassembling the lifter. Once the JB Weld set the lifter was solid. I figured this would be the way to go. I disassembled a lifter to start figuring out what size and how many washers I would need. For some reason I decided to put the piston in the lifter upside down just to see what that did clearance-wise....to my amazement, it was the perfect configuration to make a solid lifter!!! With the spring and shim removed from the lifter and the piston installed upside down, the lifter cup JUST fit back in and the clip just barely fit back in the groove! This is amazing to me and hopefully helps other people out when trying to check cams.
