MrMarty51
And it now is fixed ?
Nope. The fuel shutoff solenoid arrived Sunday, but before I tackle that - on a Van a major job - I am going to try a new PMD.And it now is fixed ?
I've often wondered why, after the pmd issue was identified and the solutions figured out, that nobody came out with something.If you don't mind @royunion please share your repairs done on PMD's, you can do this in another thread if you want to keep this one from getting derailed off it's tracks! I was messing with them and came up with an idea I wanted to test that would have the transistors remote mounted away from the PMD and easily replaceable on failure. was also thinking about using some "overkill" rated transistors to hopefully eliminate the failures.
Problem I was having was being able to get the epoxy gunk out of the way safely without destroying the circuit board in the PMD. some come with soft malleable epoxy but most I have seen have the hardened type that you have to grind and chisel out!
The transistors cost too much now. https://www.amazon.com/MJ15004G-Complementary-Silicon-Power-Transistors/dp/B082S34GBKIf you don't mind @royunion please share your repairs done on PMD's, you can do this in another thread if you want to keep this one from getting derailed off it's tracks! I was messing with them and came up with an idea I wanted to test that would have the transistors remote mounted away from the PMD and easily replaceable on failure. was also thinking about using some "overkill" rated transistors to hopefully eliminate the failures.
GM did not design the PMD Stanadyne did to integrate the rehostat accelerator pedal into the gm ecm and for automatic start functions to control the Stanadyne DS4 IP.I will have to watch these vids after work.
One thing that GM never provided in their books nor could I find ant reference of online is the internal schematic or digital blueprint of the PMD it's self. I would love to find more info on the internals and components, just never found anyone who personally worked on them before other than seeing other vids on how to replace that transistor. for me just as a general hobbyist if you have that to share, that would be awesome.
On some electronics I have managed to swap out burned out components with a "heavier duty" one making it last longer than it's expected life. I like to fool around with things like that. I once had a inverter burn out one of it's mosfets rendering it almost useless. Yes they are cheap enough but as a determination I ended up swapping out the internal mosfets with ones that would handle 3 times the power and current, This didn't increase any output wattage but you could tell less heat would build up under load and seemed to work better than when it was new!
Yeah I know I'm rattling on about it, I just wish some of these other aftermarket MFG's would have taken the time to examine the oem design and upgraded them with overkill components making them last longer. then again that would put them out of business if they never failed LOL
Simply do not use a diaphragm regulator design that can crack or tear the diaphragm and fail.True, thinking about it that way, yes our 6.5's don't really have a pressure regulator, they all use the fuel pump, 99% of all gassers fuel pumps will push well into 90+ psi if they are deadheaded where ours is constantly pushing it's max where the demands of the engine exceed what it can supply. Give thanks to GM bean counters there.
for me going that route using a pump that can supply good flow and higher pressure, running a pressure regulator to limit it. I would want something else in the line for protection if and when a regulator would fail and send full pressure to the IP. maybe a pressure sensor after the regulator that would shut down the lift pump when pressure was exceeded a given amount. something that would give a warning light that you would have to manually reset so the LP would not turn back on.
I'm just a little anal on trusting a single regulator that if failed could destroy the engine not having a fail-safe in place.
Just curious, I know Ford uses DB2's on some of their trucks, did they also use the same style DS4 type? maybe we can look at how or if they regulated their fuel supply and pressure.
Ah yes I am familiar with the Stanadyne shop pitch. The shop is not allowed to give information which does not match the GM spec, for example the EP158 PUMP spec is 9.5 to 14 so that is what you tell the customer.No, Ford never went for ds4. Thats when they dumper the idi 7.3 and introduced the 7.3 powerstroke
The pmd issue was learned and been solved for years. Just not everyone knows it yet.
It needs to be on a heat sink with at minimum the thin thermal contact pad, best is arctic silver5. Mount the heat sink on the back side of the front bumper. The equal temps and slower temp changes eliminates 90% of the failures.
The resistor arguments were settled here many many years ago, because I refuse to own ds4/pmd I can’t remember who- but a member here ran without any resistor for years and others copied to verify. It is used for setting it up and only is affect at 50 start intervals and without it the truck will still start and run once it’s been running.
As to which pmd- Leroy Diesel still sells the lifetime warranty ones that he has been selling for years. Ask him if he has had to warranty half a dozen yet….
I been telling people how we dealt with pmd in the fleet with hundreds of 6.5 trucks crushing 100,000 miles per year- was running two. Put a dummy plug in the spare. Both mounted to either two separate heat sinks or one big one. When in question- swap the wire and get on with life. If it is bad- you drive on the old spare while waiting for the lifetime warranty one to be replaced. Next week when its back- run on the lifetime again.
Absolutely the fuel pressure is big- just as big is the lubricants that are required to be added since we no longer have sulfur in the diesel. Original reports of bio fuel being high lubricants was good- but the addition of ethanol/ methanol off sets most of the B-fuels. As to the pressure- I have went from reading it at the fuel filter outlet to saying ONLY metal T connection at the ip inlet fitting because I have seen SO MANY rubber fuel lines between filter & ip and it all looks ok but is being blocked just before the ip. Search pics previously posted by myself and others.
Redoing anything other than running the modern design/built pmd & resistor is a serious waste of time. Understand not having a spare pmd ready to rock is like not having a spare tire. Pre mounted means all testing and swap is just doing some of the work ahead of time and only added cost at that point is $20 for an extra heat sink. Do the math about broke down at night, bad weather, etc especially with family in the rig or God forbid an emergency situation and it isn’t an iq higher than a dog needed to realize it should be a flat requirement to owning the ds4.
FTB mod has been done by 1 person who said it was a waste of time that I ever heard of. And when a couple of us offered to drive to him, pay time to put back 5/16 line and record results then swap to 3/8 line (FTB) and bet him $100 if there wasn’t a noticeable difference. Why would I do it? Because I have done so many ds4 & db2 “3/8 conversions” as I called it before hearing the term FTB that I know 100% it has helped every single 6.2 & 6.5 I have ever done it with. Basically it is a no brainer and it ticked me off this guy was swearing it didn’t help and infact was hurting it. Notice that clown never shows up. Several people question it- which I understand. Two people have said it’s illegal- Roy and a guy in Europe. The guy in France had a Hummer, and another Hummer owner met him & showed him his with a FTB. Within a month they both were owned by the one guy and both had FTB. Funny part is, that guy who now owns both is a gubmint employee who oversees the division that oversees their smog requirements for his county (I can’t remember which one). hahaha.
The only thing to really debate in the fuel at this point is which additional lubricants (never use a water emulsifier) and which aftermarket lift pump & filters is worth the investment.
Less water the better- FASS has the best I have found so far. Factory filter (by Stanadyne requirements) is 10 micron nominal. So long as volume and pressure at the ip inlet is met- going smaller is always better.
Which pump- lifetime warranty cost more usually but is like insurance.
If you don’t have a pressure gauge permanently mounted-you are guessing.
The last training books I saw (afaik others here too) that were the Stanadyne training literature said 8-14 psi is proper range for ds4.
I asked before and will again:
The different spec you mentioned: please post pics of the specs and the manual they are in Including the identifier for that literature because there are misprints.
I sell no parts. I sell no services. I get no pay from any vendors (infact they get paid by me- haha). I have busted parts sells guys on multiple sites for misrepresentations. The link posted earlier in this thread for the lift pump-
I HIGHLY QUESTION IT being the best choice. Can’t say it is horrible- but there are cheaper options and there are other options that cost more on day one but have better return on investment imo.
I do have a habit of investing too much in some situations but like my Hummer with db2- it was more economical to just keep replacing the EP 158 by AC Delco, which while toted as the best factory style lift pump- is too low output for the ds4 unless you get one that an individual store will do lifetime warranty because it barely meets bottom spec when new and within a year or so falls below.
So, from a fairly obvious air intrusion problem to maybe fso, to in dash electrical short, firing the parts cannon continues with a pmd & resistor before installing the already purchased fso and still not doing what both Stanadyne say is task #1 of installing clear line in place of the ip return line to examine for air intrusion (bubbles) or other contamination then reading pressure/flow at ip inlet… Am I up to speed?
Again- please show the specifications you mentioned at the beginning of this thread as they are completely incorrect at too low and too high. I stopped by the local Standyne authorized shop to check on his supply of injector shims and had him pull up the numbers- he verified what has been in my book from the 1990s:
8-14psi
Ah yes, "made in the USA" likely always meant "assembled in the USA". The plastic case, the die cast frame and even the circuit board is likely made elsewhere imported and final assembly done here. It is a big investment to make all of that here. But flightsystems does not own the PMD business anymore, Dorman does.The flight systems pmd is made in the USA. But feel free to buy the chinese ones.
I am perplexed why you are stuck on the 8-14 psi operating range spec to insist anything else is wrong.I went through training to rebuild the pumps at the stanadyne site when they were the only authorized training center. One of the two engineers who created the ds4 taught the class. I am telling you- the pressure is 8-14 psi according to the engineer who made the thing. Your information is wrong.
And the spec for the EP158- if you look up the big testing that was done comparing all the different in line lift pumps of multiple brands and all-
The testing was done in my shop. The EP158 was the best of that style, thats why it is the one recommended by everyone. If you drive over 10,000 miles in a year- that pump won’t make it the one year maintaining pressure to the 8psi level. Most of them don’t maintain 5 psi for a year.
If you wanna run at 15 psi- you can. I know a guy who lets his gasser v8 run until the oil is not visible on the dipstick then adds so much oil that he is overfilled 2 quarts. Truck has 150,000 miles on it so that proves its smart, right?
No. There are things you do to get the most efficiency and longevity from components.
Just understand when you do pull the engine- you have shown you don’t follow actual specs and there is an obvious problem with aeration which is insane for damage to the pump & rotor so people don’t expect to get 20,000 miles from the ip from you. Jerry rig patch on the filter and still running it means they can’t trust any of the maintenance to care for the engine holds low impressions that the entire engine has low shot at even being a good core. So don’t expect more than a couple hundred bucks for the engine with all its diesel accessories. Honestly the throttle pedal probably holds more value than everything else combined if it is same pedal as the trucks- i never compared if they are or not.
It 62 pages which is the full manual for rebuild.That is not a full sized manual.
The pictures that I previously posted here, the page, and a couple other 6.5 sites in the past had that info and went into detail why they are running those specs. Basically you run it too low a pressure and too high a pressure to stress it on the bench, and because balance testing which wasn’t even covered in that link is done best at extremely low pressure.
I can’t post new pictures as I no longer have the manual. Search the sites to fund the info previously supplied.
I understand why a person can come to the conclusion you did from that- but note that no where does it actually specify what volume of fuel or minimum and maximum inlet pressure is actually listed as that. If you recall, when I mentioned listing the source, it’s because there has been info put out that Stanandyne corrected later. I don’t have the time currently to verify this link- but if others who own ds4 want- the info is available. I suggest others researching before they take the advice of myself or Roy. Or you can use some reasoning and decide to go in the middle of the two specifications and set your pressures right in the middle. My warning of being below 5-7 is simply some performance and MPG loss, nothing catastrophic. My warning of being above 14 psi is seal failure..
There’s been several people now who’ve done experiments with accurately controlling the inlet pressure than doing test drives, data, logging, etc. The people who have shared it all seem to find nine psi to be the most desirable pressure with pumps under 100,000 miles, and 10 psi when above 100,000 miles.
Search the history of people who have experimented with running higher inlet pressure and the long-term effects of the pump. No input for me as needed on their findings.
