royunion
Active Member
Spent 11/23/2024 swapping the new starter back in.Oh yes it does.
Spins the motor but won't start UNLESS the starter charger is hooked up in start mode.
It will start it cold or hot but even though the batteries are fully charged and crank the engine fast, it only starts INSTANTLY with the starter charger hooked up.
You can hear and see the glow plug load on the little generator powering the starter charger.
Even without it I can see the glow plugs hit the batteries before cranking.
No air in the line, as the gauge shows holding 5 to 8 psi when off. Any thoughts what might cause a no inject confition
