royunion
I spent the day swapping the starter again. I discovered I caused the starter problem with the new starter because, while I thought the rear bracket was tight, it was not and vibrated out the bolt and was lost to the road and I found the heat shield hanging out.I do hope that You will be posting parts for sale, in that section of this forum.
After I got it out and inspected the flex plate teeth all was well. The spare replacement was a true Delco Remy made in Japan and I knew was good.
That is why you save all bolts and the like, and I have four large clear "cashew" tubs with the big screw on caps. I had a perfect match with 13mm head!!
Hot charged the batteries again and at 14.1 volts charged the glow plugs, turned the key and she leaped right life from cold.
I discovered without that front bracket, the starter can swivel just enough to side grind on the flex plate with a terrible noise rather than crank the engine.
Batteries are fully charged holding 12.8 volts (they are flooded AGM). I shall see how long this lasts. All I can say is all day while swapping the starter, the fuel pressure held static at 5 psi all day, so I was encouraged it might start - and it did.
