if you comment on a thread, pls, first read it. thats all stuff discussed 2 pages earlier.
ive done transmission rebuilds, i own a very special shop, where folks come to when other shops can't fix it by plentiful throwing parts at it... but im 5000 miles away from my tools and have a transmission that does not behave like a failed band.
I dropped that pan, and out came 55k old fluids but no metal or clutch material, pics are in here, i pulled the harness plug, its dry. pics dito
that tells me, i have a good transmission, not a bad one.
that also tells me, i need to find the real reason, cause a rebuild is probably not going to fix it.
i know, with US automatic transmissions, because they are what they are, first step in fixing a funny behavior is, rebuild it for upwards of 4k.... might. ot fix it, but introducing a lot more reasons for more funny behavior...
all the good transmission people ive been talking too have been trying to sell me a full rebuild. and non was willing to explain to me why that would fix my issue. cause if you don't know whats wrong, do a full rebuild.
its like the traveling mechanic that tried fixing the funky idle (caused by stuck valves) for my previous owner by selling him new batteries, then a fresh fill of fuel, then a fuel pump (both times he siphoned the "old" fuel into his rig, no its not hear say, i saw that on cctv footage PO showed me after we became friends), then new distributor, wires and plugs, then new injectors (while at it, dropping a self tapping screw in the only cylinder that had no bend pushrods.) after that my PO had it towed to a good shop. who actually found whats wrong and quoted him way over 20 grand for 2 new heads and a redo of all the stuff the other guy did. so he put up this unused basically brand new 27 years old MH for sale, to give away for almost f-ing free. i came in, swooped it up, pulled the heads, polished the valve stems and brushed out the guides, grinded the one with the screw in it, put a set of new lifters and pushrods and a gasket on, now i own a 25k MH at costs below 2k. (that i ignored the cheap parts of the traveling guy came to haunt me. 1000 bucks for a tow for a worn down distributor gear that made the distributor spin freely, and a set of new injectors, cause when hot one of em was getting stuck wide open and an other one was stuck shut, funny hu?, that all in was another 2k. but back to topic)
let me tell you, a worn out band slips, it does not shift hard and then go soft. that's a sign of missing oil pressure at the servo after the shift is completed, and that's nothing that comes of a worn band or a stuck valve, broken cable, dead coil.
ther are many possibilities here, but a worn band is absolutely out of question.
in the end it comes down to anything that could starve the servo off oil pressure in 4th only. like a PCM that goes bonkers, a valve thats supposed to be in one place while it wanders due to broken spring, blown out seals that only affect the 4th gear.
i never worked with a 4L80E, hence why im here, to pick your knowledge and brains, selling me a full rebuild is not what I'm here fore. thats beend done to me already, no need to have it a second time.
and the 1-2 valve spring is one of these possibilities and easy enough to verify its good.
what i would like to do as a test is hook a manual shift box to it. and go hard 4th, see if it does the same funny things. But then, pulling TPS seams to make my PCM go into some sort of fault mode where it locks TC up and just shifts hard by rpm/speed
in the meantime im happy driving in 3rd gear. its where that engine transmission differential and tire combo wants to sit mostly anyway with pushing a 10 ton class a MH down the interstate.
oh, and we also ascertained that i have a PCM, not a TCCM or a TCM or ECM
and since it does actually store faults, its likely this PCM is a good one.
I'm certainly not going to push my multimeter probes into any plugs, thereby ruining the pins in there.... but i go get some alligator clips and im going to get me some needles to very carefully back probe my PCM plugs and put some measuring devices on them.
