Your transmission is telling you that the handwriting is on the wall. If you are lucky you can repair the electro-hydraulic portion and come out ahead. If you drop the oil pan and see a lot of "sparkly".. this will add onto your OD problems and issue.while its almost 30 years old now, my trans is just past 60k miles young, mostly driving by on old guy treating his new RV with soft paws...
from what i see, i dont feel that this trans is dead.
If you disconnect the passthrough connector you can isolate each and every electrical component at the connector with a multimeter bar none.so my next thing is get a external pig tail and make sure my problem is inside the trans vs outside the trans...
i know that Americans are notoriously bad in geography...As you well know you can drive in third gear back to your shop and take care of matters there.
