96 6.5 suburban plz help
Carl Taylor
Ok I have a 96 6.5 suburban 2wd I'm have wired electrical problems the fan motor clicks wen key is turned on wether or not the fan is on or not the stock radio will volume up to max or volume down at random interval it will drain battery over night I've never had a problem like this before and am at a loss as what to do
The HVAC harness is a known issue it will melt and make cross contact with other harnesses as the blower motor wears and draws more amps and the fuse will be of little or no help. GM sells a repair kit for this problem wires, terminals etc. been there done that!
I've never seen or heard of the repair kit.
Do you have a link & /or part number?
I've always cut and spliced to repair.
I do add a ground from the heater blower to the dash mount bolt , just inches away that seems to help.
It's been 10 year's or so since I did mine and may have the numbers will look and post.
It was a common repair kit for fleet service having the melted blower motor harness melt into other harnesses and fuse never blowing.
On of the first signs was that the blower speed switch in the HVAC control head would heat up at its contacts melting its housing when you replaced the switch it would happen again and the fans would do crazy things like work w/key off or go high when you have it on low vise a versa etc.
Hey Carl.
http://data:image/jpeg;base64,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
Carl, I misspoke it's generally the resistor harness that's the issue and kits are on ebay.
Hey Carl.
Hey Leroy enjoy your popcorn or? Perhaps being constructive would better suit the topic!
O ok is it just eBay
First, confirm this is your issue you'll find melted/burnt wires between the HVAC control head and the blower motor resistor it the harness could be melted into the radio harness also if it is then search for the GMT400 harness repair kit for the resistor to HVAC on the bay........another consideration would be a bad ignition starter switch with broken/dis-lodged rocker crossing circuits good luck and keep us apprised of your progress.
I'd still like to see a link to this kit. Does anybody have a link? Sounds like something that would be worth having on the shelf.
When I get to actually working on a vehicle, I have to maximize my use of time. I can't spend a lot of time searching for and ordering parts. I try to keep some stuff handy. I never know when I won't feel like working on something or when the next time I will be able to work on something again will be. I just keep plugging along
You have no idea as to my constructiveness on this topic. I've spent some time with Carl on the phone on this issue, but could not help him, so I suggested he make this post in the first place!
My popcorn smiley was just me subscribing to the thread. It means I don't have much to add, but I am watching and learning myself.
Im glad you posted some help though.
Then I took it wrong and now stand corrected, thank you!
