dbrannon79
I'm getting there!
I really feel like I royally screwed up by not keeping the original parts and rebuilding them! if only I had dug deeper and of course talking to you guys here first before pulling the trigger on the parts cannon! (holding my head in shame)
I did look up rockauto and they show the same parts and bore sizes. MC 1.25 and HD is 40mm. booster shows pic of my OE one with the little thingiemobob on the return port. and the wheel cylinders with the two options. right now I'm thinking on the booster not only is it not holding a reserve pedal press, but it's not the right one. And I think also my wheel cylinders should be the one with the larger bore. not sure yet on the MC but given the fact that my GVWR is 9000 might consider it a HD class truck. a trip to the dealer might be in order hoping they have the info I need.
I remember back when I was working as a mechanic in the late 90's to mid 2000's we would get GM cars and trucks in that I would see mysterious things on mid 95 models that I considered to be GM's "experimental" parts where they'd send them out from factory with parts that by application didn't call for. later I'd find out they were very common on newer 96 and up vehicles. As if they were testing out stuff before the major model change rollout's. the biggest ones I saw was in the electrical systems on 95's that were "pre" 96 models. some had odb2 connectors but we had to use an adapter on the obd1 snap-on scanner we had to read them!
