ak diesel driver
6.5 driver
ideally yes you do a full machine job for the part fill the T bros are planning it's probably not as important
The only girdle worth making or buying is one that ties the main caps into the rail of the block, PERIOD.
All others are a band-aid and some might actually be worse than leaving it stock.
Don't waste money on making or buying one. Ask any reputable machinist and he'll tell you the same thing.
All your doing with a girdle that is mounted to the caps themselves is moving them in unison, which could do more damage.
IT MUST BE TIED TO THE BLOCK, the block won't shift or move.
Look at the p400 motor for proof of a sound design.
Home made crap is just that, crap.
Please don't take my word for it ASK A HIGH PERFORMANCE ORIENTATED MACHINE SHOP.
DSG IS CRAP, show that to a machine shop and they'll laugh at you.
Save your money for mods that work. Sorry for the rant I hate to see people waste money on junk.
OK I see, that makes sense. Hmm, I am going to have to really weigh my options here.. so many choices!
Isn't it true that you need to have machining done past just a regular cylinder hone when you using block filler?
I wish DSG would sell a 5 pin girdle or sell their studs in a kit! Hmm maybe I could contact them.... thanks turbonator, you are making me think![]()
great rant.... maybe instead of just negative input you could add something useful here... maybe you should build a p-400 girdle and show us how it is done..... there is always someone who trashes what everyone else is doing but shows no accomplishments of his own.... do you even have a diesel? it is not in your signature, and with 70some posts one would think that you could at least list your truck and its mods for everyone to see? and oh yeah, performance guys have been using girdles in small blocks since the 1960's..... hmmmm they must all be wrong according too you....
The TA Performance block girdle is a must with any higher horsepower or high RPM Buick 400-430-455. The conservative casting of the factory Buick big block has main webs that are approximately 3/8” thick which is adequate for stock and mildly built big blocks, but is far from what it should be with serious HP and RPM. Buick engineers used a combination of a conservative casting with a large main journal crank to distribute the loads found during a stock application. However, severe main cap oscillation takes place when power levels go beyond the 600 HP mark, when RPM levels are above 6000 and/ or with the use of heavy aftermarket steel crankshafts.
The TA girdle is made from 1” thick high tensile strength ductile iron which is stronger than the iron used in the block itself. The girdle requires installation by a machine shop and when installed the girdle is an integral part of the block. The main caps must be cut and machined to fit within the saddle of the girdle. The girdle ties into the pan rail to complete this structural upgrade. This is the only way to prepare your foundation for the potential horsepower that these big blocks have. (Use of any type of girdled oil pan, no matter what type of material used will only give you a false sense of security). Ask anyone using a TA block girdle that has had a rod bolt break or Nitrous mishap, and they will tell you that the block stayed together. All that was needed was to refurbish the engine and they were back to business. Why spend so much money to race prep a block then have it gone in seconds due to a mishap.
The design of the TA girdle will help prevent blocks from distorting, cranks from breaking and main webs from cracking, all while allowing the use of a stock or deep sump oil pan. Each block girdle is machined to clear the starter, and crank counterweights and comes with complete instructions, main studs, other required hardware and necessary spacers for a complete package. Weighs 25 lbs.
Haha well a P400 is unfortunately WAY out of my budget, thats more than I have in the whole truck, almost twice as much! Also, who sells the P400?? I have heard about the motor but I can't remember who sells it. Maybe I could get in contact with them about the girdle.
However, I can see how a well made steel girdle like turbonator's could help as well, since it transfers the stress from one to all which essentially strengthens the weakest one, yet I guess kind of weakens the stronger. However, the real world testing they have done with theirs is certainly a testament to its strength, and I am impressed with what their 6.5 can handle.
Those of you that have mentioned tying the caps to the block, where does the girdle tie into the block?? Could you make like "individual" girdles that tie each end of each cap onto the block??
Thanks guys!
