vdb11
Halfmoon Detroit #2
I never thought of it that way!
Well here is my thought though, the dsg kit only comes with the three outer studs, which as I found out are $6.65 a piece, plus the nuts and washers come in ten packs so I might as well do all ten outer holes, if i buy the dsg kit, I would still need 4 studs so thats $27 plus the nuts an washers. While I would like to have the kit, I think I will just buy the studs and then make my own girdle with angle iron kinda like you guys did.
But now that you mention studs pushing down and bolts pulling up, would putting studs on just the outers stress the caps in anyway since the bolts will still be in the inner holes?
Thanks a bunch guys, you have been a huge help!
