vdb11
Halfmoon Detroit #2
OK guys here goes.
I willing be rebuilding/building up my 92 6.5 this summer (hopefully). I have already begun to assemble some parts for the job. From my testing, it seems as if I have one dead cylinder and it burns some oil so the motor needs a rebuild, and I wanna build it up![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Here is the list, most of this stuff I am sure about, but I do have some questions on a few items:
New rings and bearings all around (bought)
Main girdle
Block hardener (Moroso or Hard-blok?)
Ported lower intake, heads, and pre-cups (by me)
All gaskets necessary for rebuild
New water pump
New HB and pulley
Holset HE351 VGT turbo (already have)
Remanufactured head and rotor and modified DB2
Possibly intercooler (have)
FTB mod
Oil cooler lines fixed
Ok so like I said, I have much of this stuff figured out, but I still am unsure on some things. Keep in mind I am on a tight budget.
Main girdle I am still on the fence about, I don't trust myself to do it right but we will see. As for the main bolts, what do you think? Could I possibly get a grade 8 bolt, run a nut and washer up it, lop the head off (enough to get a socket on nut) and essentially have a stud??
Block filler. This may seem really dumb, but in our application, does it still go in the water jackets? Does that actually make the bottom end of the block stronger for us? How much should I do, and what kind of machining other than running a hone through the cylinders will I need??
Head bolts. I don't plan on running much more than 15-16 psi even with this set up, and studs are too expensive for me, would regular head bolts from Advance or somewhere be fine?
Water pump. What year should I get? I will be getting a reman most likely and I noticed there is a good size price difference between like 97 pumps and 2000 pumps. I just want one that will flow reasonably more than my 92 pump.
Also when I take out my IP, do I need to score the gears to maintain timing? I ask because I will have the IP apart anyways for the machine work.
Feel free to comment on anything on the list. As for the IP and turbo, I am pretty well set with that, but the bottom end stuff I will take suggestions. If you see anything I should add let me know. Thank you!
Also, I hope to get a dyno run in here this weekend or next for a base run to see how much power I can add after all this is said and done. I am sure I forgot some questions.
Thanks!
Vance
Main girdle
New water pump
New HB and pulley
FTB mod
Thanks!
Vance
