88gmctruck
02GMCtruck
I don't let things sit around. Basically all free time goes into my current project till it's done.IIRC starting in 96, but it may have been later, GM went to a bigger input shaft on the C3500HD chassis cab, so a guy can run a HD input and clutch and get the big input that way.
you are coming along way quicker than I can even comprehend, stuff is done in days and weeks around here (occasionally months and years :O )
Once you get the parts, duh.
Now I see what you've been busy working on. So, when can I bring my 4500 over for a rebuild?
If you want to convert a GM or Dodge trans between eachother I know you need the bellhousing and input shaft. If you want to run the correct t-case then you also need the mainshaft and tailhousing.Your probably right, I dont remember. It was something like if you are swaping trans from one to another you would need the input shaft from one (dont remember sorry)
