When I replace the factory system, I'll pop the extra cash and go stainless and it'll most likely be 3 inch.
The aluminum cross over from warpspeed was a thing of necessity right now seeing as mine is rotted....
Is there something wrong with having an aluminum cross over?
Has anyone upsized the crossover tubing to 3" at all?
Well I don't see it hurting anything really. I was gonna touch up my manifolds on the inside with the die grinder when I get the chance to...
Did you quit doing work on your trucks?My Dually goes in Thursday for the 4 inch...![]()
Warp speed is "aluminized" if I recall.
Meaning, steel tubing covered in aluminum.
Nothing wrong with it other than corrosion resistance.
Is the corrosion concern from the inside out, or the outside in? If it were painted with high-temp paint, would that protect that concern?
