5.7 diesel up and running
Back in 80s my Dads brother had one of those Olds diesel cars it was blue in color. He was a truck driver for years, then he started his own truck sales business. He also liked diesels so he had to have him a diesel car. I can remember hearing that car run, I thought it was so cool to hear it. I can't recall him having any major issues with it, I really wouldn't know for sure because he lived about 300 miles away.
When I first bought that cav unit about 15-20yrs ago it had the filters with glass bowls and an o-ring top and bottom which would occasionally cause leaks,etc so I kept the unit and found the conversion kit to allow a spin on filter to be used.Its a great conversion.
My single looks identical, but has an aluminum bowl
I got hooked into these engines because my father bought his C10 back in 1980.Its a 1979 but the original D block snapped a piston pin gouging the cylinder wall so I was interested in finding another 5.7 diesel to go back into the truck when I became old enough to work on it.I’ve been hooked ever since….lol.
Here’s a old picture I found of the 5.7 diesel using CAT head bolts.You can see the cat stamping on a couple.They are the 1/2-13 like what gm used back in the day.I find hardened washers under CAT head bolts if anyone decides to use them makes a huge difference.
Cat has never used split lock warshers.
Always hard flat warshers only.
Their thoughts and ways are best.
Why would any install a component thats already broke on anything.
Many times I have used that theory, pulled lock washers and installed hard flart warshers.
I would only use flat hardened washers also.It would probably of made a huge difference under the gm bolts.
Cat definitely uses split lock washers, internal and external lock washers.
They just don’t use them everywhere. Only where needed and the best type for the area. Old cats vibrated so bad that they had a ton of problems with split lock washers breaking, then the bolt/ nut loosens up.
When at worked at a fleet for a mining company, we had a lot of cat equipment. They had their own hardware bins that were cat specific.
So they worked with different fastner companies for custom options. Anyone familiar with Stage 8 fastener system- they were created for Cat.
They basically figured out that more often than not a split lock washer will fail or will fail in o retain. Im pretty sure they worked with permatex for inventing medium strength locktite.
