ak diesel driver
6.5 driver
Mines always taken along time
I can't get the www.*getdieselpower.*com
link to work anymore.
Still looking - mostly procrastinating before I go out in the cold.
How do you get the 4x4 floor shifter cover off?
Is there a place to access key on power under the connection cover on the right hand side of my 94 K3500? By the lift pump fuse?
I attached the brown wire up through the Shifter on the 95 Tahoe. But if I can access key-on power there I think that would work better.
If you have not got it figured out yet. The spacer goes in the hole that the old actuator comes out of. Just push it in there and forget it. Screw your new larger plastic actuator in the hole and snug it up. Plug in the wires to the actuator (this should be very self explanatory). OK. Take that LOOONG brown wire and carefully feed it back around the engine and up over the top of the tranny. Here you have two options. There is a sensor/switch on your transfer case. It too has a brown wire coming out of it. You can
A. splice directly into this wire and call it good.
or
B. Get in your truck, and pull all of the trim out from around your T-case shift lever. Once you can see the wiring harness coming through the floor open up the loom. You should see the same brown wire in that loom. This is generally the best place to splice into, since it is out of harms way and you dont have to worry about water and mud etc. getting into the connection. Dont get frustrated because its sometimes a pain in the ass to get the brown wire into the cab... but trust me it can be done.
to work anymore.
http://www.tahoeforum.com/showthread.php?t=15162
Thank you, Thank you very much
Apparently the really awesome pictures didn't copy and paste
