Bullseye240
OK, so is there any detriment to keeping the front diff locked all the time? I know that you'll get the front tires fighting themselves if you crank it while it's in 4WD, but what about if the transfer case is in 2WD?
Posi lock actually sells a full time lock kit for the front axle. Myself I can't see any reason to worry about the front end being locked all the time. It's basicly the same as a front wheel drive system in a car. As long as you leave the transfer in 2wd it won't bind up but if you forget it will. However thats also true of the stock setup.
