Michaeljp86
EVIL GENIUS
How do you take it out of low do you have to put the trans into N? It would be kick ass if you could just put it back in high, then it would be like having a 2 speed rear end.
I have the quite large 'big boy' style on my 97 factory. Not sure if it because I also have the borg warner T/C. It works flawlessly, I need to be rolling about 2-5 mph and can hear the teeth 'grind' a tad before it engages. I use it often as I do most of my plowing in 2wd, unless I think I may need 4wd. As always, the key is to have it in 4wd BEFORE you need it.
Really? Grinding?
My 98 goes in and out without a single word of protest. At a standstill or rolling...
My 89 was thermal, my 98 is servo.
Night and day difference. Can't even say how great it is.
If you want to keep it without the hassle of yanking the front diff into engagement every time you shift to 4x4, I highly recommend converting to the later model servo actuator.
Of course, you could just leave a posi lok engaged all the time I guess....
I ordered a new OEM actuator GM part number 26060073 off Ebay for $76.50 and the harness update GM part 88959465 from oehq.com for about $53.
Teflon tape, mine came with that on it. Screw it in all the way to the bottom, which should come naturally.
The thermal actuator is small, not much is visible outside the diff at all. The new design is essentially a stepper motor and is quite large outside the axle housing.
The TLA next to the posilock aftermarket piece. The "dirty" part of the TLA is all you see when installed:
Solenoid/motor style (98 and up):
That was an excellent post (with the picture). Thanks.
It takes my actuator between 10-11 seconds to engage. Is this about right?
