Husker6.5
Also, the Harness Connector pin out diagrams also have voltage at the pin listed in the NVG 246 Transfer Case section. Not all powered pins have 12V! Some are 8V! I'll take pics and post those, too.
NO! The CD-ROM does NOT have PDF files on it, it lets you ACCESS GM's files on their corporate mainframe for multiple vehicles besides the GMT C/K platform! This is used by a dealership's maintenance department instead of having hundreds of volumes of manuals taking up a storage room! I actually loaded the CD-Rom to my laptop, it only took up a few hundred Kb of space and a shortcut icon on my home screen to directly access. You MUST have internet connection to use the data base.depending on what type of files are on the CD, most service manuals we have here at work are simply a collection of PDF files with a small program that catalogs them in an index. you could easily zip it up in a compressed file for emailing or uploading onto a private cloud storage giving a link to it for Big T
Look at the component diagram in the second set of photos I posted, with the title Transfer Case Relay. Its harness leads to the relay that is on the lip of the firewall/cowl behind and above the transmission dipstick.I looked all over the engine compartment and don't see a relay as depicted. The only thing attached to the back firewall is a plug for the underhood light. Guess I would need to do some harness tracing from the actuator, but it's just too cold right now.
I bought a disk reader from walmart a while back. Plugs into the flaptop and functions just fine. I think it is also a recorder device too.I will probably want the CD. Need to check my laptop in Fullerton if it has a CD reader. Or my son might have a laptop with a CD reader.
Hmmm. I'm using the 1998 Second Edition set of manuals published in 1999 by GM. Doesn't say anything about OBD1 in it or for K3500 only for the application, in fact all the DTC Codes it runs through in trouble shooting and what the codes mean are all OBD2 P0XXX codes. Perhaps a later Edition/update has that.I think the Transfer case relay is only for OBD1 trucks. Its in the 95 wiring diagram. Buy not listed in the 99 wiring diagram. It also says for k3500 only next to it.
Sent you a DM for address and payment info.Yeah, you should get either the 4 Volumes or the CD-ROM, @Big T. The NVG 246 Section is 96 pages that covers the wiring, operation and diagnosis/fixing of DTCs for the NVG 246! TONS of illustrations, schematics, connector pin assignments, etc!
I’ll blame that on Will L. If it’s not the clear fuel return line, then it’s a f’n ground.That's a hellofa body / cab ground cable ya got there!
I bet you say that to all 6.5 owners.That's a hellofa body / cab ground cable ya got there!
