Well this was a new one..... last night I went to put the oil pan on and as I was getting the bolts started by hand I couldn’t get one to go in. I took the bolt out of the pan hole and I couldn’t see a hole. Great, a bolt broken off in the block. So I pull the pan back off......uh......there isn’t a hole there in the block at all!!
Then I look at the oil pan original to that block and sure enough it didn’t have a hole in that location either, but as you can see the factory gasket had a hole there. Weird!!
So I start Googling.....some blocks have a hole missing and some don’t. Some older LS1s and some trucks I’m finding. I know people have swapped the iron LQ4 into Trailblazer SS’s before so there must be info. Nope....can’t find anything. I keep searching throughout the night on the interwebs and in Facebook TBSS groups and no info. Ok, I’ll ask on TBSSowners.com and the Facebook groups in the morning to see what others have done.
Then I look at it again - screw that, I don’t care what OTHERS have done, I know what I am going to do! I wasn’t happy with it not having that bolt there for two reasons: 1. Looks like a good place for a future oil leak and 2. Since the front diff is bolted to the pan there has to be a good amount of stress on the pan in that area.
Luckily the holes are outside of the outer wall of the block, so there wasn’t any fear of really screwing up the block. So I decide I am going to drill and tap it. As I thought about it more I thought it would be easy to make it nearly foolproof: I’m going to make a drill bushing. So that’s what I did tonight after work.
First I bolted the pan to the block so I could use a transfer punch to mark where the hole should be.
Then I go drill a 1/8” hole in a nice square block of steel I got from work. I then use the drill bit and the center punched divot to locate the bushing. I then clamped it to the block with vice grips.
Then I drilled the hole, being sure to stay nice and straight.
Next I drilled the bushing out to the size I needed for the tap: 17/64. Again I used the drill bit to locate the bushing and clamped it in place.
Now the hole is 17/64s, straight and chamfered.
I then hand tapped the hole with an M8x1.25 tap. No sweat.
Note that I masked the entire engine off with plastic sheeting and duct tape to keep any and all shavings out of the engine. This project was a 100% success. On to tackle the next hurdles.
