3500_6.5
I don't believe so. I had to advance it some when I put the stock lift pump back on, but I messed with it a bit and seems to be in a decent spot. I do think performance wise that it could be advanced more, but it's right on the edge of getting the clanking noise at idle of the "extreme" advancing.
The pump just puts out a lot of fuel. Way more than a tuned ds4 or turned up mechanical pump is capable of. Almost double the amount of a stock mechanical pump at 3500 rpm and I would guess quite a bit more than double at lower rpms. It needs a lot of air and it needs it early.
Sent from my ST26a using Tapatalk
